Instagram freezes on S22 Ultra and also freezes the System UI
s.
All other functions run normally on the phone. However everytime I open instagram, the app freezes. And then the System UI also freezes. Tried uninstalling and clearing the app cache. Doesn't work
hast du nach dem Update mal ein Wipe Cache und Repair Apps gemacht.
hier hatte ich mal eine Anleitung erstellt
If I open instagram either from Google Play or from the menu it opens but I have a screen with no options. I tried uninstalling but on the S23Ultra you can't completely uninstall the app. I did clear the data and cache already but to no result. 7988157
To whom it may concern, I am a big fan of Samsung Notes and I truly believe it is the best note taking app out there for android devices. However I have some improvement ideas I would like to share! Here are my ideas: ● allow more specific colors in the taskbar for better workflow (currently 3...
I am not able to access the details of my SS cloud data summarized on Samsung Cloud with an PC only. If I click on "Gallery", or "Other Synced Data", a verification notification is sent, that I can only access with a modern mobile Samsung device logged into the same account. My SM-T595...
Hi all, so i just got my hand on my S22 Ultra two days ago, and i cant say im satisfy with it. Bought it new form Samsung direct, but since i received it, it has frozen twice and had to be forced to reset, i also cant get a few gesture features to work, like the screenschot one. Is there anyone...
If you want to play something like a game (Genshin impact) is playable up to a point where the game is start to freeze and if i want to see my fps with the app from the developer options,all is ok i can see the fps but after the gallery,Instagram,Snapchat it will start to crash.This problem you...
