Kompatibilität von S20FE-Charger mit S22 Ultra - Erfahrungen und Tipps gesucht
d.
Is it fine to use S20FE charger on a s22 ultra please if somebody knows let me know
Ja, das ist überhaupt kein Problem. Das Laden dauert auch nicht wesentlich länger.
I have the same Phone as you. But i think IT is better to use the 25 Watt fast Charger
Wieso empfiehlst Du den 25 Watt und nicht den 45 Watt Charger? Hat das einen bestimmten Grund?
Actually Iam thinking to buy a 45 or even 25 because this 15 is a bit slow it took 25 minutes to charge the phone from 57 to 88
Hello, I bought S22 ultra few days back. It is brand new. After setting up the device it got many updates and the latest update is One UI 6 based on android 14. I have seen significanr battery draining. For example if I charge it full then unplug it, in the morning I see 19% charge is already...
Hi all, so i just got my hand on my S22 Ultra two days ago, and i cant say im satisfy with it. Bought it new form Samsung direct, but since i received it, it has frozen twice and had to be forced to reset, i also cant get a few gesture features to work, like the screenschot one. Is there anyone...
Hi everybody I need one info because I am having s22 ultra already 3 months and before 20 days when I wanted to unlock phone shortly I saw like some screen issue. It was green screen with pixels and lines showen but very shoetly like one second like some kind of deffect a hole screen and than it...
I got my long waited S22 Ultra yesterday after more that 5 weeks of waiting. Unfortunately I don't have yet the USB C dock charger so I used the old one to charge it. Today I connect it to my laptop with the USB C cable provided in the box, surprise!!! the cable works only on the "charging port"...
L: Galaxy S22 Ultra hello everyone, i have just switched from apple a couple of weeks ago. I bought this phone since it was the flagship of samsung, however ever since i switched i was never satisfied with anything from this device. I am an esports player and some of these issues are really...
