Unlock notification details on screen lock after face recoginzation
d.
Ich would like to use it like on my uphone before means to get the notification details listed on my screenlock bit first after my face has been recoginzed. Currently it is only possible to completely hide the nitification details or always to show them. No dependencies on face regonization implemeted.
  • Android: Screen Mirroring
Und wie kann man Dir jetzt in einem Userforum helfen? Es wäre doch sinnvoll das als Wunsch an Samsung zu kommunizieren. Vielleicht wird die Funktion mit einem der nächsten Smartphones ausgerollt wenn dies gegen keine Patente verstößt.
Kommt mal so eine Funktion mal von Samsung? Diese sollte unter Android 11 mal kurzzeitig vorhanden gewesen sein.
Wie gesagt, da müsstest Du mal Samsung fragen was die so in der Entwicklung haben. Hier ist ein reines Userforum. Ich nutze den Fingerabdrucksensor, ich weiß leider nicht ob die Funktion einmal zur Verfügung stand.
Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
Hallo everyone. I would like to request an update on the lock screen where once the phone is unlocked with face I'd the notification are readable. Currently when the screen is unlocked the notificsations stay locked until the screen is swiped. This udate would be really helpful. Regards, Adil...
Y
Hai I been using Samsung S21 Ultra since February and have been facing two issues with the phone. 1) (The main and most frustrating thing) Grainy vedio capture in low to indoor condition. The vedio is grainy like a budget smartphone infact my realme 6 pro capture bettwe vedio indoor. I am not...
WhatsApp calls not displaying on screen after upgrading to One UI5. I just get to hear the ring. Then I need to unlock phone. Pull down the notification panel and open WhatsApp to accept the call. Please help ASAP. 6604804
I am not able to access the details of my SS cloud data summarized on Samsung Cloud with an PC only. If I click on "Gallery", or "Other Synced Data", a verification notification is sent, that I can only access with a modern mobile Samsung device logged into the same account. My SM-T595...
