samsung j3 screen lock
t.
hello,
my mobile screen is locked and i forgott the password how to open it
  • Android: Screen Mirroring
Hello,
this is a big problem because it is the purpose that the device can be locked and not easily unlocked.
But if you still have the purchase slip, you can go into one of Samsung's CUSTOMER SERVICE PLAZAS and they should then be able to unlock it.
On this Page you can look where is the nearest to you: CSP
translated with Google translator
If you have enabled Find my Mobile and the remote access in your smartphone, you can enable it on the Find My Mobile page.
Hello,I'm using a galaxy s5 as second phone and would like to delete the old Samsung account (I don't have the password and also could not reset it). Could someone help?Thx. 6632227
Hello, I have recently bought a new Samsung Galaxy M32 phone and I'm having a sound problem. When I play music using wired headphones, there is a constant clicking noise on the background and it keeps playing until the music is stopped! I don't know how to get rid of it, please can someone help...
Hi, quick question; before I updated to android 10, I had a Smarthings device panel directly in my Notificationcenter. It showed a seperate icon vor every connected device along with its battery status and a little extra button for smartview. I loved that feature! I could see how much battery...
Hello, I will write in english it will be easeir for everyone. Almost one month ago I bought this phone, and so far I encountered following problems with it: Front and back cameras got huge problems with focusing, especially front one. Front camera cant focus at all, its forced to keep...
Hallo everyone. I would like to request an update on the lock screen where once the phone is unlocked with face I'd the notification are readable. Currently when the screen is unlocked the notificsations stay locked until the screen is swiped. This udate would be really helpful. Regards, Adil...
