forget to put watch 6 in cart and order my phone
I preorder the S24 Ultra but forgot to put watch 6 in the cart and the reference number. is there any chance I can get watch 6 or should I cancel the order and re-order it again?
help me as soon as possible
I mean I have code and everything. is it okay, If I order a new phone? and cancel this order. I just ordered 4 hours ago only
Nein. Die Aktion ist letzte Woche schon beendet worden. Keine Chance!
Das kannst Du doch sogar in der Mail nachlesen das es keine Watch mehr gibt.
okay, thank you so much for all of you to give me a reply as soon as possible. appreciated.
Hello there. Hope everyone is doing fine. My order for the S23 Ultra has been canceled by my brother while doing a joke. I have received the phone and of course I wanna keep it as I have ordered it. So my question is: How can I cancel the return process? (As I said, I already have the phone and...
Hi guys! I have a gear s3 frontier watch which I bought in the U.S and also a S10+ which i got from the U.S(i currently live in Germany). I recently got the s10+ and when I tried to link my watch to it, it says that there is a reactivation lock(Even after I tried a hard reset on it ) . So, i now...
I just bought this phone 2 weeks ago and been using the s pen to draw eversince. Earlier yesterday, i used it and it works fine.. it stayed inside the phone when i put it back. But later on the same day when i use it again, and put it back.. somehow it won't stay inside. It's very loose. I...
I am having a problem. I have a US LG phone, and a US galaxy active watch 2, but I live in Germany, and I cannot get it to locate my German T-Mobile network. Both the phone and the watch are unlocked from the US Cellular companies Help!! 2057946
Problem: Apps are crashing soon after opening. I have tried all possible ways with the Samsung agent on the phone but nothing worked. It was also advised by the agent that I should try to do a factory reset but due to the number of apps and the effort to install them again, I do not want to try...
