Note 10 Plus: Probleme mit Touchscreen-Deadspots trotz funktionierendem S Pen?
Q
q.
I have dead spots in my note 10 plus screen , the s pen seems to work totally fine but the touch screen have dead spots and sometimes it works and sometimes it doesnt , when i lock and unlock screen it gets fixed for some milliseconds, i tried safe boot , restarting , removed the case , turned off touch sensitivity and everything but still nothing is changing
Wenn Du eine Hülle mit Magneten nutzt dann entferne diese einmal und versuche dann noch einmal.
Ich habe bereits erwähnt, dass ich das Gehäuse entfernt habe
Dann solltest Du Dich vielleicht einmal mit dem Samsung Support in Verbindung setzen.
Hotline (allgemein) 06196 77 555 77* oder gebührenfrei unter
0800 72 678 64 oder buche einen kostenfreien Rückruf zum Wunschtermin.
Servicezeiten
Mobil- und Hausgeräte: 24/7-Service
TV/AV: Mo-Sa 7-21.30 Uhr
Displays, Monitore, Notebooks: Mo-Fr 8-18 Uhr
Wichtig: Bitte halte beim Anruf deine Gerätedaten bereit
I just bought this phone 2 weeks ago and been using the s pen to draw eversince. Earlier yesterday, i used it and it works fine.. it stayed inside the phone when i put it back. But later on the same day when i use it again, and put it back.. somehow it won't stay inside. It's very loose. I...
Today i was using google maps with my galaxy note 10 while on a bike. Since I was on a bike and could not use the phone simultaneously. I put the adress and place the phone in my pocket. Accidental touch sensor is already on. Every 2 minutes the phone chooses anotherocation and ad a stop it was...
Hi, I use the new tablet A9 SM X115 (8,7 ") and have problems with the swipe right function. I can not use the news feed by Google Discovery using the swipe right touch function, although the start screen shows the Google Discovery button and this function is enabled there. I already...
Hello, since two weeks I’m not able to charge my phone via an USB-C charger. If I charge it via normal USB it works - but slow. I thought the issue comes from the USB connector module, but after replacing it I still face the same issue. Basically, any charging device with USB-C exit does not...
I am with Samsung since the S2 I uses many versions of S and Note and even A but I always have a screen problem starting with S6 edge + and Note 8 and Note 9 and A 70 , a week ago I ordered the S21 ultra but I recieved the telephone with present inside, shake the telephone and you can hear...
