Android 12 Update for S21 Ultra
What kind of update? The August Patch is avaliable for S21 series.
Perhaps the Update to Android 12 will be available in November or December like the last years for S20 and S10 Series. But there are no official Information from Samsung.
Und warum bitteschön schreibst Du das nicht sofort mit in die Frage? Dann sind auch keine Rückfragen notwendig.
HI L: @Zura123,
I have optimized your thread name so everybody can see on first sight what your question is. *1f642.png*
Kind regards
L: @Zura123 das Update auf Android 12 kommt sobald es fertig ist, ein Release Date gibt es nicht. Voraussichtlich wird wie wie jedes Jahr ca November die Beta-Phase starten
Falls Zura123 die Überschrift nicht nachträglich geändert hat, stand da von Anfang an "Android 12".*1f609.png**1f609.png**1f609.png*
Scene optimizer icon is available when I open camera application. But when I change the lens it disappears (not available for 0.6x, 3x, 10x). I tried to close the camera application and reopen it. Still the same issue. 4929671
Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
Will the galaxy s21 get the android 14 update? 6578529
Hello guys,I've recently updated my Galaxy phone to the new Android 12 version and I've immediately felt a big change in the vibration, it feels cheep and it's way louder than before.Is it just my phone or someone else is having the same experience? 4357959
I signed up for the Android 12 Beta but did NOT install the Beta yet. Still running Android 11 with OneUI 3.1. Now I want to withdraw from the Beta program without installing the Beta itself. How do I do it?There is no such option as stated in the Beta FAQs inside the Samsung Members app. 4001275
Ľ
