Which is the best USB C to HDMI 4K 60Hz adapter/hub for S21?
m.
Can someone let me know, which is the best adapter or hub for using 4k display at 60Hz with S21?
Thank you. Gelöst! L: Gehe zu Lösung.
These two support 4K @ 60
Samsung EE-HG950
Samsung DeX Cable
Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
Hello, I noticed something annoying with the Galaxy S21. When I scroll slowly in an app, you can see a wobble / lag / jitter / jump. I can reproduce the behavior on another S21 which has been reset. The behavior is also seen on an S10, which is not as extreme. It's not as noticeable if you don't...
Hello. I am writing in English. I am in Switzerland. I have the Freestyle beamer. And I have several USB external drives, a Samsung Blu-Ray player, and game consoles which I have been using for years on my Samsung smart TV. As I am transitioning to use only the Freestyle I would like to know how...
I am with Samsung since the S2 I uses many versions of S and Note and even A but I always have a screen problem starting with S6 edge + and Note 8 and Note 9 and A 70 , a week ago I ordered the S21 ultra but I recieved the telephone with present inside, shake the telephone and you can hear...
Samsung ince again changed the way to boot into recovery.As some of you already know, you now need a usb cable connected to a PC Wow, i know nobody with a PC anymore. We got rid of those things a few years back beacause thats why the h*** we got these expensive phones. Why would you do that? No...
