Probleme mit WLAN-Verbindung beim S23 Ultra - wer noch?
R.
Hi everyone. I got my S23 Ultra on 3rd February.
Does anyone else have a problem with the phone randomly disconnecting from wifi?
Its quite annoying.
I've posted a similar issue this morning. I was getting just around 5-10 Mbps whereas my old s21 ultra had 40-50 Mbps. The fix for that was changing the router settings from 2.4 GHz to 5 GHz. On my router I just can switch between those two but on newer ones you can activate both so you have one wifi for 2.4 and one for 5. So maybe google the name of router and how to change or separate the two wifi channels.
I have a Vodafone Station router. I'll separate the 2.4 GHz and 5Ghz and let you know whether anything changes in the next 24 hours.
Ok. If this doesn't help, try resetting the networking settings.
Hey Everyone! I have done a pre-order of the S23 Ultra from Samsung.de. But now I have found a Great deal somewhere else. So I want to cancel my Pre-order from Samsung, and grab the other one. What's the procedure for that? 6890676
Hello there. Hope everyone is doing fine. My order for the S23 Ultra has been canceled by my brother while doing a joke. I have received the phone and of course I wanna keep it as I have ordered it. So my question is: How can I cancel the return process? (As I said, I already have the phone and...
Also an alle, die Probleme mit dem WLAN haben: es soll wohl mit dem nächsten Update gefixt werden. Das Problem ist bei Samsung bekannt. Es liegt nicht unbedingt an euren Routern, sondern scheint ein Bug zu sein...
Hi there, I jave Samsung phones for years and always faced Navigation issues with Google Maps. But with my S23 Ultra, it was perfect so far. But for some weeks now, the same issue comes up again: during Navigation, suddenly the map does not turn into the walking direction anymore. Sometimes it...
Hello, I apologise that I'm writing in english but it is easier for me to explain the problem. I have a frustrating issue with my phone. I bought Samsung S23 as a brand new around 3 months ago. It was working fine till last week - I started to have problems with the signal connetion - the...
