Problem with Gboard after a system update - Galaxy Tab S7+ 5G
F.
I was happy with my Gboard but after an update, now when i tap the mic , it open a new window and is total useless .
You can see in my note 10 plus, after i tap the mic button ,in same window i can use it and everything work great :
How i can reverse this useless update ?Thank you-----------------------------------------My Tablet :Galaxy Tab S7+ 5GSM-T976B
Android-Sicherheitspatch-Ebene:1. März 2021
Software version :T976BXXS2BUC1 / T976BOXM2BUC1 / T976BXXS2BUC1
It's because you didn't anchor the keyboard and that's it, or am I wrong?
And updates cannot be undone, at least not in the official way.
I am trying to use my Galaxy Tab S7 as a learning platform with the SKOOVE app, connected to my e-Piano (Roland FP-30X) through a new USB-cable (connecting the USB-Host socket on the e-Piano with the USB-C socket on the tablet). Unfortunately, the MIDI-connection does not seem to function...
Guys, whats going on here, my tab s8 ultra after update on UI5.1 every minute pass the battery goes down. As you can see from the screen picture i always charge the tablet until 85% and i use it until max 20% and today this happening. In 60Hz, flightmode, wifi on, low brightness, nightshift...
Hi all, i have a problem with my Samsung Galaxy Tab A7 10.4 (2020) SM-T505 (LTE) 32GB. It was updated today 20.03.2022 with official latest security update via wifi (normal usual way) (i think Feb or March 2022) but after that i can not turn my tablet any more. I have all data phone numbers...
So i use my tablet ( Tab A8 ) alot but in my Home its very warm so sadly, the glue of the Display melted and i need to press on my Display to hold the glue (Its only on the right side in the corner, The same Happned to my Samsung J6+ the back Glue melted and the back completly falls off so i put...
Hey, Since I updated my Galaxy Tab S7 plus to OneUI 4, every time Im entering DeX mode with sidepanel pinned and leaving, there are 2 sidepanels pinned. One I can unpin but the other one is there until I restarted my tablet. Does anyone have the same bug or know a better solution for it? Both...
