I have 2 units evo 850 of 1tb. both failed and do not work,
c.
I have 2 units evo 850 of 1tb. both failed and do not work, any ideas what I can do ..?
  • Daten übertragen: iOs zu Galaxy Smartphone
    Daten übertragen: iOs zu Galaxy SmartphoneHier erfährst du, wie du deine Daten von einem iOS-Gerät auf dein neues Galaxy Smartphone übertragen kannst.
Ein paar mehr Infos wären sehr hilfreich. So wird dir niemand wirklich helfen können.
An internal disk from one day to the next was not detected by the equipment, I thought it could be loose but no, I installed it on another computer but it does not work either, I installed it as an external drive but it does not work, I installed another of the same characteristics and in passing a few days I also presented the same problem.
In this caes you better contact the support from Samsung:
Dear Samsung / Dear Community,  I have been doing some research on this topic and only find discussion about encryption basics, like if SW or HW encryption is better. But I feel like my question is something for real IT-Pro's so I try my luck here. Please only answer / give advice if you have...
Hast du Erfahrungen oder Probleme mit der Samsung SSD 850 EVO 1TB, SATA (MZ-75E1T0B), die du teilen möchtest? Würdest du die SSD weiterempfehlen? Samsung+SSD+850+EVO+1TB%2C+SATA Samsung SSD 850 EVO 1TB, SATA (MZ-75E1T0B) Spezifikationen: Bauform: Solid State Drive (SSD)...
Hello everyone, I just received today my Galaxy Book Flex2 i7 and I have two concerns that I would like to know whether they are normal or I have had bad luck and got a defect device: 1. The touchpad click is triggering a "rattling sound" as if some keys on the keyboard were loose. The left...
I read many many post people have same problem with S21 series and note 20 series. I paid phone 1300 euro and I have problems with this phone. Before that used S10+ Premium edition NO PROBLEM at alfor double less money. Note 20 Ultra was working when I bought it. Problem start with on update...
Hast du Erfahrungen oder Probleme mit der Samsung SSD 850 EVO 1TB, M.2 (MZ-N5E1T0BW), die du teilen möchtest? Würdest du die SSD weiterempfehlen? Samsung+SSD+850+EVO+1TB%2C+M.2 Samsung SSD 850 EVO 1TB, M.2 (MZ-N5E1T0BW) Spezifikationen: Bauform: Solid State Module (SSM)...
