Spülmaschine DW60M6040BB: Buzzer not working
A.
I've had this dishwasher for almost 3 years now. A few months ago, the buzzer stopped working. I have looked at all the manuals and parts lists I can find, but none of them show where the buzzer is located. Is it possible to repair?
    Hello L: @AK421,
    to make sure I don't misunderstand: with buzzer you are referring to the auditive signal the dishwasher usually makes as soon as a programm finishes - or did you mean something else?
    Your machine is eligible for the Self Repair Service. The manual for that can be found (in English and German), when you put in the model code on this page. However, I had quick look and it doesn't seem to include your issue, unless of course, I misunderstood.
    For any repairs done by qualified personnel, you may contact the specialists via phone at 06196 77 555 77 (Monday through Saturday, 8 am to 8 pm). If you're based in Austria, please contact their Samsung service. In Switzerland please contact the Swiss customer service.
    Kind regards
    Hi L: @NathalieB, thank you for your response and advice.
    Yes, the buzzer is exactly that, the auditory signal that the dishwasher makes when finishing a program or when pressing the buttons.
    I had a look around the manuals as well and couldn't find anything. Thanks for the suggestion.
    I can only assume the buzzer is part of another component, perhaps built into the control panel.
    I'll contact the specialists and see if that helps.
    Thanks again.
    The nearby option is not working so I cannot share/receive any file. I even open the Google - Device connections - Nearby Share but nothing happens. It hangs. Nothing is shown. (It was working fine before the last update) 3386525
    Since a few weeks, almost all the apps on my A52s 5G prompt a message after just a few minutes of normal usage that there is no Internet connection (or something of the like), or the apps stop working/refreshing. At first, I thought this was an issue with Meta apps (Insta, WhatsApp, etc.). But...
    Hi all, After a recent update the smart view app has stopped working. It is not able to find other devices in the network and also stays in the status disabled. I gave all the permissions to it. Can any support in fixing this issue? 2859264
    We just purchased a new refrigerator (RL36T600CSA/EG) from MediaMarkt.de (on 21. 05.21). The device was delivered to us at about 8:30am yesterday and we let it stand for up to 7 hours. After switching connecting it to power source at around 4:15pm, as directed in the manual, we set it to the...
    Antworten in Deutsch sind auch okay. Hey,I recently purchased the new Galaxy Book Pro 360 and at first everything was working perfectly. After a few days of usage the included Spen stopped working for no reason. It just does not get detected anymore and doesnt allow any interaction with the...
