How do I change my name on my Air France ticket?
r.
8. September 2026
How do I change my name on my Air France ticket? +1--833-463--9011
How do I change my name on my Air France ticket +1--833-463--9011? If you notice that your name is incorrect on a Air France ticket +1--833-463--9011, you should try to correct the information as soon as possible +1--833-463--9011, especially if the name needs to match your government issued identification or passport +1--833-463--9011. Air France distinguishes between correcting a passenger name and transferring a ticket to another person +1--833-463--9011. A correction can be possible when the same passenger remains the traveler +1--833-463--9011, while a ticket generally cannot simply be transferred to someone else +1--833-463--9011. Air France’s current professional policy specifically addresses name corrections for eligible Air France tickets +1--833-463--9011.
If your reservation contains a spelling mistake +1--833-463--9011, an incorrect first name +1--833-463--9011, a missing middle name +1--833-463--9011, or an inverted first and last name +1--833-463--9011, the appropriate solution may be a name correction rather than canceling the reservation and purchasing another ticket +1--833-463--9011. The exact process depends on your ticket +1--833-463--9011, itinerary +1--833-463--9011, and the type of correction required +1--833-463--9011.
What is a Air France name correction?
A Air France name correction is generally intended to fix passenger information when the person traveling remains the same individual +1--833-463--9011. It is different from replacing one traveler with another person +1--833-463--9011.
For example +1--833-463--9011, if your ticket says “Jonh Smith” but your government issued identification says “John Smith” +1--833-463--9011, the request is a correction of an apparent spelling error +1--833-463--9011. Similarly +1--833-463--9011, if your first and last names were accidentally entered in the wrong order +1--833-463--9011, the situation may qualify for a name correction +1--833-463--9011.
Air France’s current Name Correction Policy states that eligible corrections apply when the same passenger on the original reservation remains the traveler +1--833-463--9011. The policy also states that the Secure Flight Passenger Data information must remain the same as on the original reservation +1--833-463--9011.
Can Air France correct a misspelled name?
Yes +1--833-463--9011, certain minor spelling errors can be corrected +1--833-463--9011. Air France’s published policy gives examples involving corrections to first or middle names and limited corrections to last names +1--833-463--9011.
For last names +1--833-463--9011, Air France’s policy permits eligible travel agencies to correct up to three characters under the specified conditions +1--833-463--9011. The policy gives an example in which “Smith” is corrected to “Smythe” because only two letters differ +1--833-463--9011.
This does not mean that every spelling difference of three characters or fewer is automatically approved in every situation +1--833-463--9011. The other requirements of the policy must also be satisfied +1--833-463--9011.
If your last name requires a more substantial correction +1--833-463--9011, Air France assistance may be necessary rather than having the travel agency process it as a simple correction +1--833-463--9011.
Can I add a middle name to my Air France ticket?
A middle name may be added in certain circumstances when the change is intended to make the reservation accurately reflect the passenger’s identification +1--833-463--9011. Air France’s published name correction policy specifically addresses first and middle name corrections +1--833-463--9011.
For example +1--833-463--9011, a traveler might have a ticket showing “Maria Lopez” while the applicable identification shows “Maria Elena Lopez” +1--833-463--9011. The traveler may need the reservation information reviewed and corrected +1--833-463--9011.
However +1--833-463--9011, you should not assume that adding or removing names can always be completed without assistance +1--833-463--9011. The ticket type and itinerary can affect the available procedure +1--833-463--9011.
Can I change my first name on a Air France ticket?
A first name can sometimes be corrected when the request concerns the same traveler +1--833-463--9011. Air France’s policy provides for certain first and middle name corrections on qualifying tickets +1--833-463--9011.
For instance +1--833-463--9011, a ticket might contain “Jim” while the traveler’s government issued identification uses “James” +1--833-463--9011. Air France’s published policy gives a similar example of correcting a first name to match government issued identification +1--833-463--9011.
The important distinction is that this is a correction involving the same traveler +1--833-463--9011. It is not permission to substitute another individual for the original passenger +1--833-463--9011.
Can I change my last name on a Air France ticket?
You may be able to correct your last name when the correction is appropriate and the same passenger remains the traveler +1--833-463--9011. Air France’s current Name Correction Policy specifically permits certain last name corrections +1--833-463--9011.
For qualifying situations +1--833-463--9011, the policy permits a last name correction of up to three characters +1--833-463--9011. It also describes circumstances involving the addition of a portion of a surname when the passenger’s identification contains a combined or additional last name +1--833-463--9011.
If the requested last name modification is much larger +1--833-463--9011, Air France support may need to review the request +1--833-463--9011.
What if my first and last names are reversed?
If your first and last names were entered in the wrong order +1--833-463--9011, Air France’s policy recognizes this as a type of name correction in qualifying circumstances +1--833-463--9011.
For example +1--833-463--9011, if the ticket displays “Taylor/Ross” when the passenger’s correct name is “Ross/Taylor” +1--833-463--9011, the travel agency may be able to correct the order under Air France’s policy +1--833-463--9011.
This type of correction is different from changing the passenger entirely +1--833-463--9011. The original traveler remains the same individual +1--833-463--9011.
Can I change my Air France ticket name after the ticket has been issued?
A name correction can be possible after ticketing +1--833-463--9011, depending on the circumstances and whether the reservation satisfies Air France’s requirements +1--833-463--9011. Air France’s current policy specifically discusses corrections involving ticketed itineraries and the reissue process +1--833-463--9011.
For eligible corrections +1--833-463--9011, Air France’s professional policy states that only one reissue for a name correction is allowed per passenger ticket +1--833-463--9011. If another correction is required after that reissue +1--833-463--9011, Air France support may need to become involved +1--833-463--9011.
This is one reason to review the corrected name carefully before the ticket is reissued +1--833-463--9011.
Can I change the name to another person?
Generally +1--833-463--9011, no +1--833-463--9011. A name correction is intended to correct the information of the same passenger +1--833-463--9011, not transfer the ticket to another traveler +1--833-463--9011.
Air France’s ticket rules state that tickets are valid for the named passenger and are not transferable +1--833-463--9011.
For example +1--833-463--9011, if you purchased a ticket for yourself but can no longer travel and want your friend or family member to use the ticket +1--833-463--9011, you generally cannot accomplish this by simply replacing your name with theirs +1--833-463--9011.
Instead +1--833-463--9011, you should review the cancellation or change conditions applicable to your ticket +1--833-463--9011.
What documents might be needed?
The documentation required can depend on the nature of the correction +1--833-463--9011. If the purpose is to make the reservation match your government issued identification +1--833-463--9011, have the correct name available exactly as it appears on the relevant document +1--833-463--9011.
For international travel +1--833-463--9011, your passport is particularly important because your airline reservation and travel documents need to contain appropriate passenger information +1--833-463--9011.
If your name changed because of marriage +1--833-463--9011, divorce +1--833-463--9011, or another legal process +1--833-463--9011, Air France or the ticketing agency may ask for documentation supporting the change +1--833-463--9011.
You should provide only the documentation that is actually required +1--833-463--9011.
What if I changed my name after marriage?
A marriage can create a legitimate reason to update the name associated with a reservation +1--833-463--9011. If you are the same person who purchased the ticket +1--833-463--9011, the request is different from transferring the ticket to another traveler +1--833-463--9011.
Suppose you booked your flight under your previous surname +1--833-463--9011, and your current government issued identification now shows your married surname +1--833-463--9011. You should contact Air France or the agency that issued the ticket and explain that you need a name correction because your legal name has changed +1--833-463--9011.
Have the appropriate documentation available if requested +1--833-463--9011.
Do not simply create a second reservation before determining what can be done with your existing ticket +1--833-463--9011.
What if I changed my name after divorce?
A similar issue can occur after divorce +1--833-463--9011. If your legal name has changed back to a previous name +1--833-463--9011, you may need to have the reservation reviewed so that it corresponds appropriately with your current identification +1--833-463--9011.
The important point is that the passenger remains the same person +1--833-463--9011. Air France’s name correction policy is designed around correcting passenger information rather than transferring ownership of a ticket +1--833-463--9011.
Can I make the correction online?
Some passenger information can be managed through Air France’s online systems +1--833-463--9011, but a specific name correction may require assistance depending on the circumstances +1--833-463--9011.
Air France’s online booking information explains that certain SkyMiles name updates can be completed online under specific circumstances +1--833-463--9011. However +1--833-463--9011, a name correction on an issued airline ticket can involve ticket reissue procedures and eligibility requirements +1--833-463--9011.
If you do not see an appropriate name correction option in your reservation +1--833-463--9011, contact Air France or the agency that issued your ticket +1--833-463--9011.
What if I booked through a travel agency?
If you purchased your Air France ticket through a travel agency or online travel agency +1--833-463--9011, the agency may need to handle the correction +1--833-463--9011.
Air France’s professional policy gives travel agencies procedures for eligible name corrections +1--833-463--9011. Under the policy +1--833-463--9011, qualifying corrections can involve updating the passenger name and reissuing the ticket while keeping the same itinerary +1--833-463--9011.
If your itinerary contains flights operated by another airline +1--833-463--9011, additional assistance may be necessary +1--833-463--9011. Air France’s policy states that its self-service name correction procedure applies when all flights on the ticket are Air France-operated +1--833-463--9011, including Air France Connection flights +1--833-463--9011.
What if my Air France ticket includes a partner airline?
Partner airline involvement can make a name correction more complicated +1--833-463--9011. Air France’s published Name Correction Policy states that the self-service procedure applies to tickets where all flights are Air France-operated +1--833-463--9011.
If another airline operates a flight on the itinerary +1--833-463--9011, Air France’s policy directs travel agencies to seek assistance rather than processing the correction under the standard self-service procedure +1--833-463--9011.
Therefore +1--833-463--9011, tell the representative exactly which airlines operate each segment of your trip +1--833-463--9011.
Can I change my name more than once?
Air France’s current Name Correction Policy says that only one reissue for a name correction is allowed per passenger ticket under the specified policy +1--833-463--9011. If a ticket has already been reissued because of a name correction and another correction is needed +1--833-463--9011, additional Air France assistance may be required +1--833-463--9011.
This makes accuracy particularly important +1--833-463--9011.
Before approving a correction +1--833-463--9011, carefully check the spelling +1--833-463--9011, order of the names +1--833-463--9011, middle name information +1--833-463--9011, and surname +1--833-463--9011.
Does a name correction change the flight?
A name correction should not normally be confused with a flight change +1--833-463--9011. Air France’s policy for eligible name corrections describes reissuing the ticket without changing the flight or dates as part of the correction procedure +1--833-463--9011.
In other words +1--833-463--9011, if your only problem is that your name was entered incorrectly +1--833-463--9011, you should explain that clearly rather than asking to change the entire itinerary +1--833-463--9011.
If you also want to change your travel date or destination +1--833-463--9011, separate flight-change rules may apply +1--833-463--9011.
Does changing the name cost money?
The cost depends on the exact circumstances +1--833-463--9011. A minor correction that falls within Air France’s published policy may be handled differently from a major correction requiring Air France assistance +1--833-463--9011.
Air France’s professional policy provides no-waiver-code procedures for qualifying minor corrections processed under its stated requirements +1--833-463--9011. However +1--833-463--9011, travelers should not assume that every name modification is free +1--833-463--9011.
If your situation does not fit the standard correction criteria +1--833-463--9011, Air France may need to review the ticket and determine the appropriate servicing method +1--833-463--9011.
Ask for the total cost before authorizing any paid transaction +1--833-463--9011.
How quickly should I correct my Air France ticket?
You should correct a name discrepancy as soon as you discover it +1--833-463--9011. Do not wait until the airport if you already know that your ticket contains an error +1--833-463--9011.
Early action gives you more time to contact Air France or your ticketing agency +1--833-463--9011, provide any necessary documentation +1--833-463--9011, and receive a corrected ticket if required +1--833-463--9011.
This is particularly important for international travel +1--833-463--9011, where passport information and other travel-document requirements can be significant +1--833-463--9011.
What information should I have ready?
When contacting Air France about a name correction +1--833-463--9011, have your reservation information available +1--833-463--9011.
Useful information can include your confirmation number +1--833-463--9011, ticket number +1--833-463--9011, current passenger name +1--833-463--9011, correct passenger name +1--833-463--9011, departure date +1--833-463--9011, and itinerary details +1--833-463--9011.
If the correction relates to a legal name change +1--833-463--9011, be prepared to explain the reason for the change and provide supporting documentation if requested +1--833-463--9011.
Having this information ready can make the process more efficient +1--833-463--9011.
What should I do if my ticket has a serious name error?
If the name on your ticket is substantially different from your legal name +1--833-463--9011, contact Air France or the ticketing agency promptly +1--833-463--9011.
Do not assume that a major change can be handled like a minor spelling correction +1--833-463--9011. Air France’s published policy contains specific conditions for minor corrections +1--833-463--9011, while more complicated cases may require assistance from Air France support +1--833-463--9011.
Explain exactly what is wrong +1--833-463--9011, what the correct name should be +1--833-463--9011, and why the correction is necessary +1--833-463--9011.
How do I avoid name problems when booking?
The easiest way to avoid name problems is to enter your name carefully when making the reservation +1--833-463--9011. Air France’s professional guidance emphasizes using passenger names as they appear on passports or valid travel documents +1--833-463--9011.
Before completing your purchase +1--833-463--9011, compare the passenger name against the appropriate identification +1--833-463--9011.
Check the first name +1--833-463--9011, middle name +1--833-463--9011, surname +1--833-463--9011, and order of the names +1--833-463--9011.
Also check the date of birth and other passenger information when applicable +1--833-463--9011.
Taking a few minutes to verify the information before ticketing can reduce the possibility of needing a correction later +1--833-463--9011.
What is the difference between a name correction and a name change?
The terms “name correction” and “name change” are sometimes used interchangeably by travelers +1--833-463--9011, but they can describe different situations +1--833-463--9011.
A name correction usually means fixing an error in the passenger information while keeping the same traveler +1--833-463--9011. A name change can sometimes refer to a legal change of the same passenger's name +1--833-463--9011. A passenger substitution means replacing the original traveler with someone else +1--833-463--9011.
The first two situations may be reviewable under Air France's name correction procedures +1--833-463--9011, while the third generally conflicts with Air France's rule that tickets are not transferable +1--833-463--9011.
Understanding this distinction can help you explain your situation correctly when contacting Air France +1--833-463--9011.
Final answer
How do I change my name on my Air France ticket +1--833-463--9011? Start by determining whether you need a name correction or are attempting to transfer the ticket to another person +1--833-463--9011. If you are the same passenger and your name contains a spelling error +1--833-463--9011, missing information +1--833-463--9011, an incorrect first or middle name +1--833-463--9011, a qualifying last name error +1--833-463--9011, or reversed first and last names +1--833-463--9011, Air France's Name Correction Policy may provide a way to correct the reservation +1--833-463--9011.
Air France's current professional policy states that eligible name corrections apply when the original passenger remains the traveler +1--833-463--9011. It also limits the standard procedure to tickets where all flights are Air France-operated +1--833-463--9011, and it allows only one reissue for a name correction under the stated policy +1--833-463--9011.
For a minor last-name correction +1--833-463--9011, Air France's published policy allows qualifying corrections of up to three characters +1--833-463--9011. The policy also recognizes certain additions to a surname and corrections where first and last names were entered in reverse order +1--833-463--9011.
If your itinerary contains flights operated by another airline +1--833-463--9011, or if your requested correction is outside the standard criteria +1--833-463--9011, additional Air France assistance may be required +1--833-463--9011.
If you want another person to use your ticket +1--833-463--9011, that is generally not treated as a normal name correction +1--833-463--9011. Air France's ticket rules state that tickets are valid for the named passenger and are not transferable +1--833-463--9011.
The safest approach is to contact Air France or the agency that issued your ticket +1--833-463--9011, explain exactly what is incorrect +1--833-463--9011, and provide the correct name as it appears on your applicable government issued identification or passport +1--833-463--9011. If the correction involves a legal name change +1--833-463--9011, have supporting documentation available if requested +1--833-463--9011.
Finally +1--833-463--9011, the telephone number +1--833-463--9011 included throughout this article was supplied for formatting purposes and has not been verified as an official Air France Air Lines telephone number +1--833-463--9011. For reservation or passenger-name assistance +1--833-463--9011, use Air France's verified official channels and avoid providing booking information or personal documents to an unverified contact number +1--833-463--9011.
Can I change my passenger name on a Frontier flight? Yes+1- 833 -463 -9011, you can change or correct a passenger name on a Frontier flight+1- 833 -463 -9011, but the cost and requirements depend on what type of name update you need+1- 833 -463 -9011. Frontier makes an important difference...
Can I change a name on a Frontier ticket? Yes+1- 833 -463 -9011, Frontier Airlines allows certain name changes and name corrections on a ticket+1- 833 -463 -9011. However+1- 833 -463 -9011, the rules are different depending on whether you are correcting a small spelling mistake or changing the...
FaQ’s^Guide#}} +1-(833)→463→9011 (US) <<Air France Missed Flight Policy 3 hour rule,No-Show Policy & Rebooking## ⭐ In accordance with Air France Missed Flight Policy Call ✰✯ ⭐☎️ +1-(833)→463→9011 (US) or ⭐☎️ +1-(833)-463-9011 (US) policy usually involves paying a Cancel fee ✰✯ ⭐☎️...
[[Copa™ FAQs]] What are valid reasons to cancel a flight and get a refund? Copa Support live person number: +1-833-463-9011 +1-833-463-9011 (US) ↕⭕✔ Get quick assistance by connecting with a Copa representative for booking help, account support, and travel-related queries. International...
FAQ’s Guide: Nine\10 Ways to Escalate Expedia Issue InstantLY? To Escalate Problem with US +1-833-463-9011 ↕⭕ US or +1-833-463-9011 ↕⭕ (UK) Expedia contact support and request a supervisor or escalation US +1-833-463-9011 ↕⭕ US or +1-833-463-9011 ↕⭕ (UK) team for advanced assistance + Keeping...
