help
    Was für ein Smartphone. Klinke oder Bluetooth? Wie wäre es mit einer vernünftigen Beschreibung des Problems?
    Have you tried a restart or checked if anything ist stuck in the headphone plug?
    Then you'll have to wait till the port is completely dry. It still senses a shortage in there.
    If it doesn't work after drying, try this app from the Google Play Store. It works on Event Android Device.
    Dear all, For last two week, post android update, my phone A40 is getting switched off automatically...I switch on the phone every time....I bought the phone 2 years before.... Request your help 3333297
    I updated my phone (samsung galaxy a21s) and after that I couldn't open my notes. I restarted the phone and found some "hacks" on YouTube but ended up deleting my notes. I backed them up and they still weren't there and I had really important stuff in there so I need them back can someone PLEASE...
    How to stop remote sim mode on my A 53 turning on so my Bluetooth works in the car. My old phone worked perfectly using data. Been living with this problem for six months Just want to turn it off. *1f635.png* 7519894
    So i went to developer settings on my phone and i put a different dpi and i accidentally turned off developer settings and now im stuck with it . pls jelp 3581110
    I have a Samsung Galaxy A51 with Android 11. I bought it about a bit less than a year ago I think and I use old Samsung headphones (wired, not Bluetooth) from an older phone. They never caused any problems. But since a few months, every time I plug in my headphones, after a few minutes, my...
