Samsung Wallet Probleme: Keine Lösung trotz Kundenservice - Hilfe gesucht!
d.
Anyone having issues with samsung wallet? What is going on..called customer service and said technical problems..but this has been for days and nothing still..any help would be great..
Ich habe auf keinem meiner 4 Samsung Smartphones Proleme mit Wallet. Erkläre doch bitte einmal genauer wo es hakt, vielleicht hat ja einer von uns Usern eine Idee.
es lädt nicht mit fingerabdruck, split pay funktioniert nicht. Konto zeigt, dass alles normal ist, aber überhaupt nicht funktioniert
Naja wenn der Support dir sagt, dass es zur Zeit technische Probleme gibt, kann man dir doch schlecht helfen, weil es ja nicht an deinem Smartphone liegt sondern an Samsung. Da hilft nur warten.
Some of the ideas I havs Hello members, I had some ideas for S Health, which you can see above! Some may like them, maybe others don't. I hope you'll find interest for it! 1. Having a feature from the Wearable to calculate our time we stood (Standing Time, something which has been seen from...
My name is utkarsh modi and I am really sorry if I will be use harsh word but this is really serious issue . I am really disappointed with your phone quality and customer service. I purchased a Samsung s20+ phone in November 2020. As a first purchased with Samsung I was really cared about my...
The German reseller "Congstar" is a subsidiary of the largest carrier "Telekom" and uses their network. Telekom activated VoLTE several years ago. Congstar only did so last year, as 3G is going to be shut down on 06/30/21. The Galaxy S7 works beautifully with VoLTE on the Telekom network but...
Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
I'm not sure when it happened, but viewing the all apps screen and switching to the work profile apps is now close to impossible. The Work Profile button is seemingly behind the back button now, which means every time I try to tap it, it prioritizes the back action over going to the work...
