Z Flip 4: Nur 3-4 Std. Bildschirmzeit für Social Media, Youtube und Spotify?
m.
I have the Z Flip 4 for over 3 days now and I noticed a terrible Battery LIfe. I am only getting 3-4 Hours Screen Time, I am only using the Flip for Social Media, Youtube and Spotify, I don't do games. Battery Drain is terrible even on Standby mode, I used Light Performance Profile, I also activated Background usage limits for apps still to no avail. #Akku #Battery #Batterie #Akku
Das ist in den ersten Tage nach Kauf normal. Gib dem Gerät eine Woche, danach wird die Laufzeit besser.
Das Handy wird in den ersten Tagen des Gebrauchs an deine Nutzungsgewohnheiten angelernt.
Und mit YouTube und Spotify hat er ja auch nicht unbedingt die Energiesparer installiert.
Well it is most likely that your next Flip 4 will have the same issue.
And like I said, it's typical in first 1-2 weeks that the batterylife is pritty low on Samsung devices. In that time the AI of your divice learns how you use the phone. It will optimate the powerconsumption on how you use the phone in that time.
I defer. I received a new Flip 4, today. And after a full charge from 1pm until now around 9:30 Pm, I still have 70% of Battery with about 2 hrs screen time. And mind you, I am doing exact same things on this phone as I have done with the phone that I returned. I definitely see the difference in the battery life. Maybe I was just one of the unlucky ones who might have received a phone with factory defect.
Hello! I'm trying to install Android 12 One UI 4 on my Z Flip 3, but so far I can't find the notification for it anywhere (from top banners, or benefits). Is there any step to perform in order to get Samsung Members App to show me the link for enrolling to beta? 4290090
Hello community, I've had my phone since February this year. Battery life has gone really bad in the last month or so. I need a full barrel charge for 4 hours screen time, mainly social media. Compared to 10 hours before. I do optimize my apps, phone, brightness and so on. But still battery now...
On 05.12.2023 I updated to Android 14 using OTA. and everything went as it should. But after install I noticed fast battery drain and the phone display is hot to the touch even while i'm writing here, when i listen to the music using BT earphones the display is also hot even if it's off. I read...
Hello, I bought S22 ultra few days back. It is brand new. After setting up the device it got many updates and the latest update is One UI 6 based on android 14. I have seen significanr battery draining. For example if I charge it full then unplug it, in the morning I see 19% charge is already...
3K
Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
