Within possibilities
s.
Having a single device to cover all needs seams quite possible these days.
Ofcourse i am speaking of dex, its moving in the right direction, not to say that it can use a bit of accelaration. Nevertheless a single device to work at an instance, play on demand and stay on the move, what else would I need to stay on top in this time and age.
    Moin, verstehe nicht was Du jetzt meinst?
    Was hat DEX mit dem Bild jetzt zu tun?
    The image to me signifies, the hidden boundaries that we might need to overcome with technology to stay on top in the modern life.
    Is there anyone who has dissatisfaction on camera performance? I am not talking about the picture quality. I am talking about the speed of opening camera app.I've experienced so many times that I missed the moment and scene I wanted to take a picture due to slow performance.That is very annoying...
    Hi guys, gals, and others, I have a question. Lately, after the Update on March 3rd, I am experiencing a weird bug. The Folders I have created with different apps and grouped them, tend to disappear. I had it by now at least three times, with different Folders and they only come back once I did...
    Hi, after few years of using another brand I decided to try the new s21 ultra, and I'm completely disappointed.. It's not normal when you have a phone who pretend to be the best from the best and you have 12gb ram and 256gb to have problems when you do a videocall and want after 10-15 minutes to...
    Hi folks, I would like to ask if any of you has the same problem as I do with S21 ultra.I've been using my phone for about a year now without having a problem on daily base.Never played games as much or some other apps that do drain the battery, so just normal usage like social media and...
    Problem: Apps are crashing soon after opening. I have tried all possible ways with the Samsung agent on the phone but nothing worked. It was also advised by the agent that I should try to do a factory reset but due to the number of apps and the effort to install them again, I do not want to try...
