Hello guys.
My device is galaxy A71 and RAM is 8GB.But when I checked the mobile information by phone info app I found _ by the app _ that A71 Look like is a refurbished one and I also check by IMEI.info I found the related IMEI RAM is 6GBANY ANSWERS PLEASE*1f625.png*
    The A71 hast only 6GB RAM. I think what you saw is RAM + "RAM Plus".
    RAM Plus is a feature that provides "extra RAM" from your internal storage.
    I updated my phone (samsung galaxy a21s) and after that I couldn't open my notes. I restarted the phone and found some "hacks" on YouTube but ended up deleting my notes. I backed them up and they still weren't there and I had really important stuff in there so I need them back can someone PLEASE...
    On 05.12.2023 I updated to Android 14 using OTA. and everything went as it should. But after install I noticed fast battery drain and the phone display is hot to the touch even while i'm writing here, when i listen to the music using BT earphones the display is also hot even if it's off. I read...
    Since a few weeks, almost all the apps on my A52s 5G prompt a message after just a few minutes of normal usage that there is no Internet connection (or something of the like), or the apps stop working/refreshing. At first, I thought this was an issue with Meta apps (Insta, WhatsApp, etc.). But...
    Hi everybody, Since few days, the wide angle camera of my Samsung A53 5G stopped working. When I select the 0.5x zoom from the standard camera app, I get an error message (Warning, camera error). I tried to clear the cache, restart the phone, restart in safe mode, without success. I tried also...
    Hello Samsung community, I recently noticed that my Samsung S21 is not able to record loud music properly. When I go to discos/Pubs/Festivals with loud music and record a video, the device distorts the bass. My device works perfectly and I use it with no case. This is strange since I didn't have...
