d.
- 2. September 2026
- 12
- 0
Provigil is a medicine which is used for treating too much sleepiness in adults. There can be many reasons for this sleep disorders like shift work disorders, obstructive sleep apnea or narcolepsy. Provigil (modafinil) is also used for treating depression. Provigil (modafinil) is different from the common anti depressants that are available in the market. Anti depressants are very famous and many doctors prescribe these anti depressants to their patients and even the patients also got used to using these anti depressants. People are not aware of the side effects caused due to the long term use of these anti depressant medicines. Generic Provigil is an alternate medicine for these common anti depressants which improve alertness in brain. Generic modafinil helps in treating sleep disorder. Generic Provigil is generally used in combination with the other medicines that you are using for treating obstructive sleep apnea. Remember that this Provigil 200mg is not a replacement for obstructive sleep apnea medicine. You need to consult your doctor before you start using provigil. Generic modafinil will definitely not help you in treating sleepiness caused due to certain conditions which are stated above but will not treat sleepiness caused due to all conditions. It is the doctor who can advise you on the best practices to get good amount of sleep. Order now +27 81 850 2816
