970 EVO Plus running hot
T.
I have transferred my EVO to a new notebook and since the SSD runs extreme hot >70c at times and then it takes ages for it cool down. That in turn heats the new notebook also up beyond normal temperatures. Any ideas, help is appreciated.
    Hello L: @Thoma5,
    That really doesn't sound too good. Please contact our SSD experts from the telephone support. They will help you from Monday to Friday between 08:00 and 17:00 under the phone number 06196 77 555 77.
    Kind regards,
    Nathan,
    thanks for getting back to me, I have been in touch with them already. It seems operating temperatures of up to 85c are normal/acceptable.
    Which is OK I guess, just not in a laptop/notebook where CPU and GPU also run under load pretty hot. I have tested some other SSDs and they run way cooler, I do not understand why but it is so. Also it seems that the start-up temperature is by the Samsung drives already 10c higher.
    But there you go, thats life.
    Cheers Thomas
    Hello everyone, i got my Galaxybook3 Ultra (i9, 32GB, 4070) yesterday and i really like the display and build quality. However i have a problem with the performance. I always use it with the original charger or at my build-in Docking-Station of my external monitor (100W Power delivery). All...
    Hast du Erfahrungen oder Probleme mit der Samsung SSD 970 EVO Plus 1TB, M.2 (MZ-V7S1T0BW), die du teilen möchtest? Würdest du die SSD weiterempfehlen? Samsung+SSD+970+EVO+Plus+1TB%2C+M.2 Samsung SSD 970 EVO Plus 1TB, M.2 (MZ-V7S1T0BW) Spezifikationen: Bauform: Solid State Module...
    Hast du Erfahrungen oder Probleme mit der Samsung SSD 970 EVO Plus 500GB, M.2 (MZ-V7S500BW), die du teilen möchtest? Würdest du die SSD weiterempfehlen? Samsung SSD 970 EVO Plus 500GB, M.2 (MZ-V7S500BW) Spezifikationen: Bauform: Solid State Module (SSM) Formfaktor: M.2 2280...
    Hast du Erfahrungen oder Probleme mit der Samsung SSD 970 EVO 500GB, M.2 (MZ-V7E500BW), die du teilen möchtest? Würdest du die SSD weiterempfehlen? Samsung+SSD+970+EVO+500GB%2C+M.2 Samsung SSD 970 EVO 500GB, M.2 (MZ-V7E500BW) Spezifikationen: Bauform: Solid State Module (SSM)...
    Hast du Erfahrungen oder Probleme mit der Samsung SSD 970 EVO Plus 250GB, M.2 (MZ-V7S250BW), die du teilen möchtest? Würdest du die SSD weiterempfehlen? Samsung SSD 970 EVO Plus 250GB, M.2 (MZ-V7S250BW) Spezifikationen: Bauform: Solid State Module (SSM) Formfaktor: M.2 2280...
