wholesale Geared Motor
Dieses Thema im Forum "Community-News" wurde erstellt von hthsdfq, 2. Juli 2019.
  1. hthsdfq
    hthsdfq New Member
    2. Juli 2019
    Gearing Arrangement:HelicalBrand Name:Chengming
    Power:3.7KWInput Speed:1420RPM
    Ratio:1:3Output Torque:60NM
    Output Speed:473rpmOutput shaft diameter:40mm
    Place of Origin:Jiangsu,ChinaAC Voltage:380V or other
    Phase:3 phaseHousing material:Cast Iron
    Type:asynchronousFreqency:50HZ
    Bearing:TPIEfficiency:IE3
    Certificate:CCC,CEColor:Grey
    Insulation:F-classTime rating:Continuous running
    Protection:IP54
    Description:
    Single Phase Small Gear Reducer Feature:
    1.The gear is made of high-strength low-carbon alloy steel by carburizing and quenching.The hardness of the tooth surface is up to HRC58-62.The gears are all CNC grinding technology with high precision and good contact.
    2.High transmission rate: single stage is greater than 96.5%,double level is greater than 93%,and third level is greater than 90%.
    3.Smooth operation and low noise.
    4.With Small size,light weight,long service life and high carrying capacity.
    5.Easy to disassemble and easy to install.
    6.Have two types.Horizontal type(CH type) installation and Vertical type(CV type) installation.
    Typical application of Single Phase Small Gear Reducer .
    Conveyors;Dumping devices;mixer,packing machine,Food industry.And so on.
    Single Phase Small Gear Reducer Ambient condition:
    1.Temperature:-10℃~ +40℃;
    2.Relative humidity:≤90%;
    3.Atmospheric pressure :Under 1000m.
    Dimension:
    Output torque:
    Our company:
    Certification:
    FAQ:
    Q:Are you trading company or manufacturer?
    A:We have our own factory.
    Q:What's your MOQ for each series gearbox?
    A:1unit is ok for different types gearbox motor
    Q:What is your terms of payment?
    A:payment<=3000USD,100% in advance.Payment>=3000USD,30% T/T in advance,balance before.wholesale Geared Motor
    website:China Geared Motor Manufacturers, Suppliers, factory - Wholesale Geared Motor - ZhengMing
