Supply Unit factory
Dieses Thema im Forum "Community-News" wurde erstellt von astao08, 25. Oktober 2019.
  1. astao08
    astao08 New Member
    25. Oktober 2019
    weiblich
    Product description
    The voltage regulator has the characteristics of no waveform distortion, small volume, light weight, high efficiency, convenient use, reliability, and long-term operation.Can be widely used in industry (such as chemical, metallurgy, instrumentation, electromechanical manufacturing, light industry, etc.), scientific experiments, public facilities, household appliances, to achieve voltage regulation, temperature control, speed dimming, power control, etc. It is an ideal AC voltage regulator.
    Normal working conditions and installation conditions
    鈼?Temperature: Ambient temperature average temperature -5 掳 C ~ +40 掳 C.
    鈼?nbsp;Altitude: The height at which the regulator is installed does not exceed 2000 meters.
    鈼?nbsp;Relative humidity of air: The average humidity of the wettest month is 90%, and the average temperature is 25 掳C.
    鈼?nbsp;Current and voltage waveform: The current and voltage waveforms approximate a sine wave.
    鈼?nbsp;The installation site does not seriously affect the regulator insulation as gas, vapor, chemical deposits, dust, dirt and other explosive and aggressive media.
    鈼?nbsp;There should be no serious vibrations in the installation site.
    鈼?nbsp;Any special conditions of use that do not meet the above requirements shall be determined by the user and the manufacturer.
    Product dimensionsSupply Unit factory
    website:Supply Unit Manufacturers, Suppliers, Factory - Supply Unit at Cheap Price - PEOPLE
