Safety Light Curtain suppliers
Dieses Thema im Forum "Community-News" wurde erstellt von astao08, 25. Oktober 2019.
  1. astao08
    astao08 New Member
    25. Oktober 2019
    weiblich
    GM40-4J Trough beam Safety Light Curtains
    The safety light curtain is a safety certified light curtain product consisting of two parts. The emitter emits modulated infrared light, which is received by the light receiver to form a protection net. When an object enters the protection net, when there is light blocked by the object, the receiver circuit reacts immediately through the internal control circuit, that is, the output Part of the output of a signal for emergency braking of machine tools such as presses, presses.
    Detection wayModelControl outputDetection distanceOptic axis distanceOptic axis numberDetection widthMin. detectable object
    4CM pitch
    Trough-
    beamGM40-4NN:NPN
    P:pNP
    J: Relay output鈮?m40mm4120mm桅50 mm
    GM40-4J
    GM40-6N6200mm
    GM40-6J
    GM40-8N8280mm
    GM40-8J
    GM40-10N10360mm
    GM40-10J
    GM40-12N12440mm
    GM40-12J
    GM40-16N16600mm
    GM40-16J
    GM40-40N20760mm
    GM40-40J
    GM40-24N24920mm
    GM40-24J
    Mains voltageN:12-24VDC J:10-48VDC/VAC
    Consumption currentUnder 100mA
    Response timeUnder 200mS
    Output formCollector open circuit NPN type: current 100mA,residual voltage 1.6v
    Output stateON when all optical axes are exposed to light
    Optic sourceInfrared ray LED
    Connection wayWith specific cable connector
    Shell materialShell: Al alloy, color filter cover: PMMA
    Environment-resisting lightIncandescent lamp: intensity of illumination of Light receiving surface3000Lx
    sunlight: intensity of illumination of Light receiving surface 10000Lx
    Ambient temperatureWorking time: -10~50掳 (but not freezing), when storing: -40~70掳-10~55掳
    Environment humidityWorking time: 35-85RH, storage time: 35-95% RH
    VibrationVibration frequency:10-50Hz,Vibration range:1.5mm
    each direction of X銆乊銆乑 for 2hours
    ShockAcceleration:500/s (about 5og)each direction of X銆乊銆乑 for 3 hours
    Our Services
    1.0Reply inquiry in 24 hours.
    2. Please kindly inform us which items you are interested & the reasonable price will be provided to you upon receipt of your new inquiry ASAP.
    3. Answer your question detailed.
    4. Solved the problem with you during using our products.
    5. Samples will be offered to you for our future cooperation.
    About UsSafety Light Curtain suppliers
    website:China Safety Light Curtain Suppliers, Factory - Wholesale & Buy Customized Safety Light Curtain at Low Price - YUMO
