Power Plant Valve factory
Dieses Thema im Forum "Feedback" wurde erstellt von dwp199488, 6. März 2019.
  1. dwp199488
    dwp199488 New Member
    6. März 2019
    Power plant gate valve, whole forged gate valve, high temperature high pressure gate valve, forged power plant gate valve, super critical gate valve for power station using pressure self-tightening structure, make sure the valve has good sealing performance under high pressure and high temperature conditions. The medium can be high temperature and high pressure water, steam, oil products and super-heated steam etc. Widely used in petroleum chemical industry, power plants and other oil, steam piping connected or cut off the medium of the pipeline opening and closing device.
    Specification:
    Pressure: 2500LB
    Material: A105
    Connection: RF Flange
    Operation: Handwheel
    Features:
    1. A welding structure is used to connect the valve and pipelines.
    2. The sealing face is op a good sealing property and long duration, uneasy to worn and rubbed.
    3. Compact structure well to be opened and closed. Lower in height.
    4. Easy maintenance.
    5. High temperature creep resistance design
    Standards:
    1) The valve manufacture and acceptance are according to Japanese power electric station plant valve standard E101.
    2) The valve face to face length according to E101.
    3) The valve welding gradient according to ANSI B16.25 or by customer's specification.
    4) Nominal pressure: PN25, PN32, P5410, P5514, P5417, P5717 MPa
    5) Nominal diameter: DN50 ~ 500mm
    6) Type of connection: Butt-welding
    7) Driving: Electric-driving, hydraulic driving, pneumatic-operating, gear-operation
    Technical parameters:
    Product Name:high temperature high pressure gate valve for power station
    Size:2inch to 18inch(DN50 to DN450)
    Pressure rating900LB to 4500LB (PN100 to PN760)
    Material:A105, F91, F51, F316, F60, F92 and so on
    End connection:butt welding
    Operation typeHandwheel, Gear, Electric actuactor, pneumatic actuactor
    Design Standards:Japanese power electric station plant valve standard E101
    Face to Face:Japanese power electric station plant valve standard E101
    Weld end standardAMSE B16.25Power Plant Valve factory
    website:China Power Plant Valve Manufacturers and Factory - Buy Good Price Power Plant Valve in Stock - Pinxin
