Other Pipe Coating supplier
Dieses Thema im Forum "Feedback" wurde erstellt von pati520tia, 31. Oktober 2018.
  1. pati520tia
    pati520tia New Member
    31. Oktober 2018
    männlich
    System Description
    The molding compound (putty) is a cold applied, flexible, non hardening compound that is designed to fill gaps and irregular contour prior to the application of XUNDA butyl tape & bitumen tape.
    Product Composition
    The molding compound is formulated with inert organic fillers in a saturated hydrocarbon polymer base.
    Product Features
    Easily applied with no special equipment
    Conformable for easy applications over irregular surfaces
    Flexibility over a wide temperature range and under various conditions.
    Product Properties
    Property Test MethodTypical Value
    Color
    Black
    Non volatile content
    100%
    Cone Penetration ASTM D937150d.mm
    Adhesion to concrete , steel
    Excellent
    Resistance to Acids ,Alkalis and Salts
    Excellent
    Resistance to Microbiological attack
    Excellent
    Temperature Range
    For Application For Service
    0℃-50℃
    -20℃-80℃
    Ordering Information
    Xunda molding compound are available in drums
    Product TypeStandard Ordering Options
    Paste ColorBlack or others
    Paste Weight per Carton box8 kgOther Pipe Coating supplier
    website:China Other Pipe Coating Manufacturer and Supplier - Other Pipe Coating Price - Jining XUNDA
