China Transfer Printing Machine factory
Dieses Thema im Forum "Let’s Talk About" wurde erstellt von ytr908, 9. September 2019.
  1. ytr908
    ytr908 New Member
    9. September 2019
    männlich
    Automatic Textile Transfer Printing Machine
    Introduction:
    Textile transfer screen printing is growing very fast in recent years because it can print more fine details and durability of modern transfer has great advantage over direct garment printing.
    Standard Printing Solution:
    KST720 stop cylinder press+ powder coating machine+ KSH1000 IR tunnel dryer +KSY1020 automatic sheet stacker
    KST series automatic stop-cylinder screen printing machine is upgrade models from rotary cylinder printing machine in recent years. This kind of machine has adopted classical “Stop-cylinder (360°)” printing movement instead of the original “reciprocating movement(180°)”. Therefore, it not only ensures the paper accurate position before scratch- printing, but also reduce the producing waster rate. Besides, there is little impact with such high speeds and revolving, which also improves the register precision.
    Technical Parameter:
    MODELKST-720KST-1050
    Max. Sheet Size (mm)720×5101050
    Min. Sheet Size (mm)350×270560×350
    Max. Printing Size (mm)720×5001050×740
    Sheet thickness (g/m2)100-35090-420
    Printing Speed (p/h)1000-3600500-4000
    Total Power(kw)8.39.8
    Total Weight(kg)38005500
    Exterior Dimension(mm)3500×2360×16003750×3066×1717
    Featured Pictures:
    Control Panel
    Screen Frame Direct Pull-out
    Printing Cylinder
    Sheet Outlet Board
    Ink Plate
    Front Pick-up Feeder
    Printing Sample:China Transfer Printing Machine factory
    website:China Low Price Transfer Printing Machine Suppliers and Factory - Buy Transfer Printing Machine - Imprint Technology
