China 5.1 Home Theatre System factory
Dieses Thema im Forum "Feedback" wurde erstellt von dwp199488, 6. März 2019.
  1. dwp199488
    dwp199488 New Member
    6. März 2019
    This Jerry Home Theatre is finished in a beautiful black & red gloss, reminiscent of a grand piano,adding a stylish touch to your decor. The Home Theater Design package comes with a center channel and four surround speakers which can be easily mounted. It has bluetooth function, which makes it easy to use.
    The distinctive side of the Jerry Home Theatre is rounded. Its driver is perfectly matched to the lacquered surface for high quality sound. This speaker gives the sound flexibility and control, creating a deep, powerful and balanced 5-channel sound for home theater.
    Parameters:
    Channels: 5.1
    Color: Black & Red
    Material: Wooden & Plastic
    Voltage: AC 220V ~ 250V
    Frequency: 50HZ~60HZ
    Accessory: A Remote Control/AV Cable/ An User Manual
    Product NameJERRY Home Theater Design Box Entertainment Center D5
    Model No.D5
    Output Power60W + 15W x 5
    Subwoofer Size6.5 Inch
    Tweeter Size613 x 5
    S/N Ratio≥75 dB
    Support EquipmentMP / PC / TV / DVD / Bluetooth / FM / USB / SD / MMC / MP3
    ApplicationHome, office, conference room, school multimedia classroom, shopping mall, specialty store, conference room, etc.
    Features:
    1.180° surround space pronunciation can control the range of sound, so the sound of is Jerry Home Theatre curved wave, scattered spread.
    2. The product is specially designed and used for family, leisure, etc. The driving part has low power and the sensitivity of the speaker is high, which can save 1/3 of the electricity.
    3. It has completely changed the conventional piston sound motion of the traditional sound, and uses the millimeter-level thin plate random vibration to pronounce, which greatly improves the service life due to the extremely small amplitude.
    Internal Parts
    DetailsChina 5.1 Home Theatre System factory
    website:China 5.1 Home Theatre System Manufacturers, Suppliers - Cheap 5.1 Home Theatre System with Low Price - Sowangny
