Cattle Drinking Water Bowl price
Dieses Thema im Forum "DVD" wurde erstellt von dsfsfb1v, 10. Mai 2019.
  1. dsfsfb1v
    dsfsfb1v New Member
    10. Mai 2019
    Description:
    The cast iron automatic cattle water drinking bowl is heavy, more strong and durable. It is recommended that the large size drinking water bowl be used for large cattle weighing more than 500KG, and select the general size water bowl for the cattle which the weight is below 500KG.
    Specification:
    Product description Product number Product size ( L*W*H) Product weight Capacity
    L size enamel surface bowl S1021H01 290mm*240mm*190mm 5KG 2.5L
    S size enamel surface bowl S1021H02 270mm*210mm*200mm 4KG 1.8L
    L size powder coating surface bowl S1021H03 290mm*240mm*190mm 5KG 2.5L
    S size powder coating surface bowl S1021H04 270mm*210mm*200mm 4KG 1.8L
    Features:
    ● High-quality cast iron material, firm and durable.
    ● Touch plate is with SUS304 stainless steel material.
    ● With standard female connection 1/2”
    ● Good surface treatment, enamel or powder coating.
    ● Two sizes for choice. The color of existing products is with black, color also can be customized.
    website:China Cattle Drinking Water Bowl Manufacturers & Suppliers & Factory - Buy Good Price Cattle Drinking Water Bowl for Sale - Stoutagri
