Aluminum Canopy price
Dieses Thema im Forum "DVD" wurde erstellt von dsfsfb1v, 10. Mai 2019.
  1. dsfsfb1v
    dsfsfb1v New Member
    10. Mai 2019
    Product features:
    Wind resistance,Impact resistance, Anti-ageing, Anti-corrosion, self-clean by rainwater, Bended design for noise reduction, UV filtration,80% light transmission.
    Bracket length: 60cm 80cm 100cm 120cm 150cm
    note: multiple sets of awning continuous assembly and free to extend.
    High quality door awning, 39 3/8" x 39 3/8" x 11"; One-piece polycarbonate sheet with seamless surface ensures no light and water leaking, much better than those consisted of 2 junctional pieces
    3/16" (5mm) clear hollow polycarbonate sheet, UV protection and designed for rain and light snow; Load capacity: 3lbs/sq.ft (15kg/sqm)
    Awnings have good weather resistance, safe, easy and ready to install
    DIY awning kit, can be installed multiple awnings for wider coverage, easily operate
    Can be used for residential or commercial applications
    Features:
    Provides excellent UV, Rain and Snow protection
    pecifically designed to resist weathering and rusting
    Safe, Easy and Ready to install
    Mounting hardware is included
    Can be used for both residential and commercial applications
    Specifications:
    - Material: High Quality Polycarbonate
    - PC Hollow Sheet (LxWxD): 37 5/8" x 38 3/4" x 3/16"
    - Wall Bracket (LxWxD): 38 9/16" x 10 1/4" x 2 3/8"
    - Aluninum Strip Length: 37 13/16"
    - Overall Dimension (LxWxH): 39 3/8" x 39 3/8" x 11"
    - Load Capacity: 3lbs/sq.ft (15kg/sqm)
    Package Contents:
    1x PC Hollow Sheets
    2x Aluminum Brackets
    2x Aluminum Strips
    1x Screw and Bolt Set
    1x User Manual
    Protection Key Features: Clear hollow polycarbonate sheet UV protection and strong plastic alloy bracket Polycarbonate sheet can easily be trimmed to your required width Design for rain and light snow Can be used for residential and commercial applications High quality door awning Awnings have good weather resistance, safe, easy and ready to installAluminum Canopy price
    website:China Aluminum Canopy Manufacturers, Suppliers - Aluminum Canopy at Factory Price - Tiansu
